Beocenter 2 with old Avant: No DVD, but CD and Radio. What's wrong?
TWG
Posts 1,672
TWG Posted: Fri, Aug 12 2016 6:44 AM
I rehired my Beocenter 2 and old CRT-Avant for the bedroom. I only want to use the speakers of the Avant. No external speakers on Avant or Beocenter 2
I've connected the Beocenter 2 with a Scart-Lead and a Masterlinkcable to the Avant.
Avant: V.Opt. 2
Beocenter 2: A.Opt. 1
DVD does not work. I experimented with different option settings but I can't get it to work 100%.
Radio and CD are working perfectly and I can listen to them via the speakers of the Avant.
What and how do I need to set up these two old babys to work like I want? :-)
Beobuddy
Utrecht, The Netherlands
Posts 3,972
Beobuddy replied on Fri, Aug 12 2016 10:18 AM
The DVD is only driven/instructed by the scart and it's cable. So make sure that have set up the connections at the back of Aavnt properly. Use "AV" and set it to"DVD/CDV".
Aopt 0 for the center (takes instructions via ML from the Avant)
expoman
Posts 182
Silver Member
expoman replied on Fri, Aug 12 2016 2:09 PM
The master link makes the TV think it is only an audio master. Disconnect it from BC2.
TWG
Posts 1,672
TWG replied on Sat, Aug 13 2016 7:18 AM
Beobuddy:
Thank you! That worked and works fine!
Super nice for the bedroom and it works nicely with my Beo 1.
Page 1 of 1 (4 items) | RSS
