A bit of a heath robinson masterlink connection using a central heating junction box off my van.
I have simply connected 3 masterlink cables together all colours like for like and the grounds together. The green tape is just holding the same coloured wires together so I didn't pull them apart as I was doing it 3 metres in the air onto one of the ceiling joists.
Masterlink to BL2000 one to BL 3500 and one to BS9000.
This is the first fix of my new pad before the ceilings and walls are boarded and skimmed.
Is there anything I have missed before the plastered puts the ceiling up??? I red 2 colours are shorted together somewhere??
Any help appreciated
plumber77: I red 2 colours are shorted together somewhere??
Master Link white-blue and pink must be connected Pin 3 ML-sense (white-blue) Pin 12 Vml (pink)
Question - can't see on your photo ? Did you also connect ALL 9 blanc wires (3 wires without insolation per cable) ?
I just connected all the wires in each cable to their corresponding coloured wire
The terminal strip had 10 connectors.
9 for each of the coloured wires and I used the last to connect all the grounds together which I read could be commoned
plumber77: I just connected all the wires in each cable to their corresponding coloured wire
It is mandatory to connect the 9 blanc wires without insolation too !
plumber77: The terminal strip had 10 connectors. 9 for each of the coloured wires and I used the last to connect all the grounds together which I read could be commoned
perfect ! Just add a connection between blue/white and pink.
Thanks for your help
