Attn: Martin or Dillen, Seeking belts & instructions for Beocord 7000
tom
pa., usa
Posts 1
tom Posted: Sun, Aug 14 2016 9:53 PM
Hello!
i have a beocord 7000 which turns on but only "clicks" can be heard when press ff, rewind or play. took a quick look at the cassette mechanism and 2 belts were visible(i read there were 3?) and appeared functional (belts and wheels turned without issue). Several threads online, including this one, refer me to Martin or Dillen to purchase belts kit and instructions for this problem. FYI- The unit hasn't been used more than 3x since purchased, most likely only 1x when purchased to test. i am the original owner and the system was in storage for 3 yrs if that helps. Any advice is greatly appreciated.
Regards,
Tom
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Mon, Aug 15 2016 10:12 AM
Tom,
You have email.
littlebear
Posts 1
Where can I purchase belts for a Beocord 7000 type 4941?
Brgds, Alf
Stefan Schinkel
Germany
Posts 1
Hello Martin,
although this post is quite old but I hope You can still supply belts for a Beocord 7000 (4941).
The cassette deck is the 3 belt version (Version 2).
Thanks and kind regards
Stefan
Dillen
Posts 13,191
Dillen replied on Sun, Sep 29 2019 11:21 AM
Sure, you have email.
peregrine
Posts 6
peregrine replied on Sat, Jun 20 2020 2:22 AM
Hi Martin,
same problem  with BC 7000, lay, forward ,reverse, does not even dis-engage heads wen stop pressed.
upon opening found one main motor to drive belt, one thick capstan belt and a small speed sensor ( I think) belt.
BTW, the heads do not rotate when auto reverse pressed, same belt issue of an unrelated electrical problem ?
Need a set of belts me thinks ...  I understand your the go to man.
Dillen
Posts 13,191
Dillen replied on Sat, Jun 20 2020 9:03 AM
Most of these decks will indeed be in need of new belts by now.
You have email.
Page 1 of 1 (7 items) | RSS
