Hi folks
I have a PS3 connected to my BV10 and can control it via the infra red eye with the Beo 4. I am going to be replacing the PS3 with a PS4. Does anyone know if I can simply plug the existing infra red eye into the PS4 and continue as before or do I need a new PUC code downloaded etc?
Any advice much appreciated.
C
Thank you. Does that mean my Beo 4 remote will control the PS4?
Sadly not PS4 cannot be controlled unless by a ps4 controller. If u find a way to control it with a beo4 let me know
Does anybody know if the RE-BL Bluetooth controller works for the PS4, too? Than we could control the PS4 just as easy as the PS3.http://www.re-bl.com/
No it doesn't. There is some info here, but it's not promising!
http://www.re-bl.com/forum/topic.asp?TOPIC_ID=1304
