Hi, does anybody know where I can buy the plastic inserts that are used to hang up my Beovox m70 (see photo)?
....or does anybody know what these plastic things are actually called?
No I don't have any, probably called a mounting bracket or something, I think you may be able to 3D print a replacement part if you have one to measure, it takes a while to program but may be your best bet
