Hello
Can anyone give any ideas on how to connect more than 1 aux input into the back on my Beosound 3200?
I want to input via my Beogram and also occasionally my iPod without having to swap the leads over
i currently have a pair of 6000s connected and the Beogram, but would like to be able to input the iPod and also the TV audio if possible (Panasonic not B&O)
Any advice or help on the best ways would be welcome
Aux Expander. Rare tho.
http://revoxbeo.homepagetool.ch/ipod-interface-for-bang-olufsen
IR version available
The best way to expand the AUX input is a nice preamplifier of your choice.that way you'll get quality inputs and - depending on the type of preamp (with or without display, with remote...) a very comfortable way for selecting additional aux-sources.
For example in this thread the old Sony TA-E2000ESD:
http://archivedforum2.beoworld.org/forums/p/20982/175037.aspx#175037
