What size screw from BG8000?
This post has 3 Replies | 0 Followers
Lee
Newcastle upon Tyne UK
Posts 734
Lee Posted: Thu, Sep 1 2016 11:01 PM
Hi Guys,
Can anyone tell me what size screws B&O used for the tonearm azimuth adjusters on the Beogram 8000?
I know they are DIN 7985 but I have no idea what size.
Please help
Lee
Lee
Posts 734
Lee replied on Tue, Sep 13 2016 5:33 PM
Can anyone help me with this please?
Lee
Posts 734
Lee replied on Tue, Sep 13 2016 5:47 PM
It's described in the service manual as
Screw AM 2x6 DIN 7985
I have assumed this means A for stainless M2 size 6mm long DIN 7985 thread.
Is this correct?
sonavor
Texas, United States
Posts 3,732
sonavor replied on Tue, Sep 20 2016 4:27 AM
Lee:
It's described in the service manual as Screw AM 2x6 DIN 7985
Is this correct?
I have never replaced that screw but the 2 x 6 means 2mm diameter of the screw shaft and 6mm shaft length.
For material, it is possible that the "A" stands for Austenitic Stainless although most examples I found of that use a designator of "A" plus a number (like A2). I couldn't find any description of metric screws or bolts where the part is listed as AM d x l.
Are you wanting to change out that screw?
-sonavor
Page 1 of 1 (4 items) | RSS
