Does anybody have any recommendations as to where to get the best fabric for recovering a set of Lab 8000 frets?
Many thanks,
Jonathan
Why not just buy new ones? They're not expensive!
Some frets are easy to re cover, but the 8000s are a bit tedious
x:________________________
Use the pantyhose method, that'll do and saves you a lot of $$$
Brengen & Ophalen
