I got a replacement Beo4 because mine is being repaired (it turns off/resets by itself when using the BACK button).
The model I got appears to be the same, except that the writing in the bottom is the classic B&O monogram instead of the full (more recent, I think) "BANG & OLUFSEN".
What I noticed though is that with this remote, the TV (BV 10-46) processes the OK button much more quickly when used with a PUC (Sky box and Apple TV), like my BR One on the BV11. With the other Beo4, when I click the OK button, it takes more or less a couple of seconds for the connected sources to register the action (which is something I always complained about to my dealer - the answer being "we always had problems with the OK button")
I wonder if this different behaviour between two Beo4 is known and if there is something that can be done with the "new" (I guess) Beo4 generation.
