B&O 2000 turntable
This post has 3 Replies | 0 Followers
Rogerthataudio
Posts 12
Rogerthataudio Posted: Wed, Sep 7 2016 3:27 AM
Hello I am a new member and a new owner of the subject table. Does anyone have a step by step on how to remove the top plate .clean and oil the mechanisms?
Seems the only issue is it needs help getting started. But with help from me rotating the table until the needle drops it runs fine there after....  so a good cleaning and new belt I am hopeing will have new life in this table.
Thanks again for any helpful relies
Rogerthataudio
Posts 12
Ok step one complete
what causes slow start I clean and oiled moving parts. Seems like the motor does not have the guts to get started.
All other functions work fine
any addition suggestion would be greatly appreciated
Rogerthataudio
Posts 12
Ok guys, looking for someone with experiences with sluggish start on Beogram 2000
Here are my thoughts on this issue:
Once it gets past the auto start sequence it run fine and retuned at the end of the record without issue.
- white gears that are turned by the platter.  seems like it need a fair amount of force to move levers  for contacting switches  are these lubtcated?  Should I take these gears off to clean and lubricate  ?
- do these servo motors get weak?  Seems like a likely problem
- belt being old  ?  I watched this cycle without the top cover and it did not slip it just stops when going through the start cycle
my conclusion is too much friction or not enough torque on the motor anymore
looking for for you assistance
thank you!,,,
Orava
Finland
Posts 991
Orava replied on Mon, Sep 12 2016 9:11 AM
BG 2000 from 70 or 80´s?
In 70´s case I would say, through disassembly, cleaning and lubrication, including motor.
Page 1 of 1 (4 items) | RSS
