hi,
i have read every thread concerning this issue and didn't find the solution.
in the connection menu, I have set the thing like this :
v.tape NONE
av DVD
decoder NONE
I plugged an old sat decoder into the av scart and a digital audio cable from another audio source into the spdif 1. I tried also the spdif 2.
when I press dvd on the beo4 I have the screen of the sat decoder but no sound coming from the speakers plugged into the beosystem 2.
i have used the rgb sound input and eberything works perfectly when I select CAMCORD on the beo4.
in the menu connection I don't have another audio option.
4 beolab 5, beolab 9, beolab 10, beolab 5000, beolab 8000 mk2, beolab 6002, beolab 3500, beovision 7 55 mk2, 2 beovision 11 46 mk4, beotime, beosound ouverture, beosound essence, beoplay A8, beomaster 900 RG de luxe and the collection continues...
The SPDIF Input might need a certain format. Try to change digital audio settings in your source (PCM/Bitstream, Dolby Digital etc.).
SPDIF 1 is the right Connection (taken from the Manual):
SPDIF 1
Digital input socket for connection of, for example, a DVD player. SPDIF 1 is for digital input from equipment connected to the AV socket on BeoSystem 2.
Ralf
Hi
thank you for your answer. I just sent audio source from internet, just simple stereo. I tried the spdif cable plugged into my beolab 5 coming from a raspberry pi with a hifi digi + soundcard, no sound at all.
That's already done Ralph with a computer. I have no more idea.
Someone on beoworld said that the spdif input reacts only to a dolby digital or dts source. I am going to check several files.
Im having the same issues getting sound to work. Anyone know how to work the beosystem 2?
olvisab: Someone on beoworld said that the spdif input reacts only to a dolby digital or dts source. I am going to check several files.
Correct. Software 2.2 and 2.3 supports DD and DTS
Older Avant's with software 1.9 support DD and PCM stereo. No DTS
