Hi guys...
I got A bang and olufsen mx4000 yesterday, I bought it to start retro gaming with, the set itself is very elegant looking imo...
I only have an original xbox to hand with a Rgb scart cable.
On setting it up, it auto detects with a scrolling image then reverts to a tv channel.
If I press v tape it goes to channel and the image scrolls quite furiously.
On the internet I found advice to set sockets to v tape 1 and v tape 2....I tried this....same issue.
The tv came with a user manual....I read it and did what it asked....put scart in av2...add aux to list and set aux to socket 2....same issue!
I don't know if....the tv don't like the Xbox Rgb......the tv is faulty...or I'm doing something wrong (is what I hope)
I have a bro 4 remote and the sw is 3.1
Any help/advice is greatly appreciated.
Thank you, Jim.
I found a digibox....hooked that up and that is fine....picture nice too....
Could it be the actual scart cable? It's a 3rd party one....
