Hello everyone, I am using the Beolink app to control my B&O devices (Beosound 9000, Beovision 7, Beosound 5). It works good, even it still have many possibilities to improving (show internet radio, etc.).
The problem I actually have having with this app is that when I select an album directly on Beosound 5 the tracks have played with the correct order.
On the contrary, when I do select an album with the Beolink app (n. music), the order changes and the tracks are played in a different order.
You can understand thath when you are listening to a concept album or symphonic music, this is a true problem.
Is it matter of settings on the app?
Can somebody help me with that?
BeoNut since '75
hello, I provided to check one album, Scary Mosters by David Bowie
this is as results:
original position position from beolink
1 9
2 8
3 2
4 5
5 7
6 3
7 10
8 4
9 1
10 6
As you can see, the order by Beolink app is true random...
exactly.....
not that I knew..... Don't you use the Beolink app?
How can it be possible that I was the only one in the world having this problem?
May I talk with someone using the Beolink app with Beosound 5?
Supposing that you are on a Windows pc, try to run these files through MP3Tag in order to have a closer look at the tags.
http://www.mp3tag.de/en/
