Where is the Avant NG?
This post has 12 Replies | 1 Follower
Solidsnake
Posts 143
Solidsnake Posted: Mon, Sep 12 2016 2:56 PM
Has anyone heard any updates on the Avant NG?  It was believed that it would be released alongside the 14 and Horizon but no sign of it.
Duels
England
Posts 2,553
Duels replied on Mon, Sep 12 2016 3:18 PM
Good question. We all seem to have forgotten about it.
Michael
Sweden
Posts 2,578
Michael replied on Mon, Sep 12 2016 3:28 PM
Nope. The Avant NG is released later on - it is better to focus on one product at a time. There will also be a semi-updated Avant in the meantime (Avant Reinstated, without the new video engine 3.0 based on Android) plus some differences (new panel for example - as the Avant NG also will have).
Due to design changes there will be a new stand but the current one will work just the same. The difference is purely to match the design of the moved panels on the back. Using an older stand will only result in a height difference between the stand pole and the panels. Only visible from the back.
The new models will feature some changes so that the contrast glass is easier to replace and the rubber gasket around the panel and glass is redesigned. A good change I suppose since it now takes a lot of time to replace the glass - and the rubber gasket is often badly placed on the current Avants.
Bv7Mk3
uk
Posts 781
Bv7Mk3 replied on Tue, Sep 13 2016 8:46 PM
If there is a new panel in the Avant ng...does that mean it will be HDR as well?
Chris Townsend
Qatar
Posts 3,531
I was told the only difference was the Android operating system, and it would amazingly keep its existing non HDR panel.
moxxey
South West, UK
Posts 5,359
moxxey replied on Wed, Sep 14 2016 9:55 AM
Chris Townsend:
So what justifies giving the TV the "NG" moniker Chris?
Chris Townsend
Qatar
Posts 3,531
Judging by some 14-55 remarks,it's short for angerWhistle
Has up to date connections too. But same old panel.
linder
United States
Posts 983
linder replied on Mon, Oct 17 2016 8:05 PM
I thought I would raise this question again.  Is there going to be an Avant NG or will the next TV be the outsourced LG/B&O TV?
phult
Posts 51
phult replied on Mon, Oct 17 2016 9:07 PM
I am looking to purchase two new TV's in January, a 75 and a 55. Does anyone have a timeline on when the new Avant's, or better yet the new LG paneled TV's, will be released.
Last thing I want to do is get them screwed into the wall the same day the new ones come out....
Best
P
Solidsnake
Posts 143
Solidsnake replied on Tue, Oct 18 2016 11:22 AM
+1
Getting close to the end of year and still no update on the Avant NG. I wonder (hope) if B&O have changed their plans to include HDR etc. on it after the backlash with the 14.
Aussie Michael
Melbourne, AU
Posts 3,730
Solidsnake:
+1
I wonder that too
Bv7Mk3
uk
Posts 781
Bv7Mk3 replied on Wed, Oct 19 2016 2:24 PM
Would be good then I would buy it! But think the old tv would be the one to get as lg and should have everything on it!
mjmedlo
Posts 922
mjmedlo replied on Thu, Oct 20 2016 2:46 AM
phult:
Best
P
I think their on the short list.
Honestly.. the android platform is hard to get used to. If you use B&O now, get the current version.
I think it's clear they're not doing the HDR update on this round.
Page 1 of 1 (13 items) | RSS
