BS 9000 clock question.
This post has 12 Replies | 0 Followers
BeoGreg
South of France
Posts 1,417
BeoGreg Posted: Wed, Sep 14 2016 11:00 AM
Here it is :
When I set the clock permanently on my BS 9000 it looks like the system won't go in full standby.
Usualy (when clock off) when I switch on the BS 9000 I get two "clicks" one for the speakers, one for the system.
When clock is on I only get one "click" when I press CD for example, the speakers.
If someone as a clue on that one, for ecological concern !
Weebyx
Denmark
Posts 1,213
Weebyx replied on Wed, Sep 14 2016 11:35 AM
BeoGreg:
Here it is :
Have noticed the same on mine, when the display needs to light up, it requires a "click" :) It's the same when doing timer programming when the system is off, you can hear the click as the red display lights up.
I guess it just needs more power than the standby can deliver, and so it turns on the "auxiliary" power also :)
/Weebyx
BeoGreg
South of France
Posts 1,417
BeoGreg replied on Wed, Sep 14 2016 1:12 PM
So I guess I'll have to wait for the next electricity bill to know exactly what's happening inside the product !
Weebyx
Denmark
Posts 1,213
Weebyx replied on Wed, Sep 14 2016 2:18 PM
BeoGreg:
I will do a test later today with my "watt-o-meter" and see if there are noticeable difference with or without clock :)
/Weebyx
BeoGreg
South of France
Posts 1,417
BeoGreg replied on Wed, Sep 14 2016 3:28 PM
That is absolutely fantastic !
Thanks by advance, I'm totally unable to do so.
BeoGreg
South of France
Posts 1,417
BeoGreg replied on Wed, Sep 14 2016 3:35 PM
That is absolutely fantastic ! Thanks by advance, I'm totally unable to do so.
BeoGreg
South of France
Posts 1,417
BeoGreg replied on Wed, Sep 14 2016 3:37 PM
BeoGreg
South of France
Posts 1,417
BeoGreg replied on Wed, Sep 14 2016 4:10 PM
That's absolutely fantastic !
BeoGreg
South of France
Posts 1,417
BeoGreg replied on Wed, Sep 14 2016 4:11 PM
Ten times moderation, ten times : thank you !
Weebyx
Denmark
Posts 1,213
Weebyx replied on Wed, Sep 14 2016 4:50 PM
BeoGreg:
My BS9000 uses 0w in std.by. without clock. My watt-o-meter might not be able to measure 2w or what the specs show as std.by power
When I press 'clock' (still in std.by), the unit clicks and the watt rises for a second to 13w and then back to 0 and stays there.
I wouldn't worry about the electricity bill with 'clock' on :)
/Weebyx
BeoGreg
South of France
Posts 1,417
BeoGreg replied on Wed, Sep 14 2016 10:01 PM
Great Weebyx, I will set the clock on as needed.
Thanks again and sorry folks for the multiple posts !
Beobuddy
Utrecht, The Netherlands
Posts 3,972
Beobuddy replied on Thu, Sep 15 2016 10:30 AM
The BS9000 is a clever designed device.
For a start, the powermanagement switches only parts that needs power. The clicking you hear is a relay that switches between different coils in the main transformer. For the reason that in standby mode, the powersupply "spills" less energy in converting AC voltage to rectified DC (+16-20V) supply to +5V.
Once a button or instruction is send, the transformator uses different (more) coils and generates a higher AC voltage to supply the rest of the BS9000.
BeoGreg
South of France
Posts 1,417
BeoGreg replied on Fri, Sep 16 2016 3:25 PM
Clock is on. Bravo.
Page 1 of 1 (13 items) | RSS
