Beoplay H5 malfunctioning
This post has 14 Replies | 4 Followers
leosgonewild
Helsinki, Finland
Posts 2,373
leosgonewild Posted: Wed, Sep 14 2016 11:51 AM
Today I had to return my H5's because of a few issues I have been experiencing.
1. During phone calls the left earplug would jitter when volume was a maximum. (Tried the exhibition models in the store, the problem was not present with these)
2. When connected, sound would play through the phones speaker instead of the earplugs. I could pause and play, but no sound was present I the earplugs.
There has been no sound issue when playing music. Very strange issues.
Will take a couple of weeks to get new ones, as they have to be shipped to Germany first Surprise
Aussie Michael
Melbourne, AU
Posts 3,730
Thanks Leo. How odd.
I nearly bought 2 pairs of green H5 tonight so I will think about them too.
These things happen with portable products. I take it there was no issue returning them
Duels
England
Posts 2,553
Duels replied on Thu, Sep 15 2016 12:32 PM
Mine are working fine. Hope you get yours sorted Leo.
Fl_ip
Posts 160
Fl_ip replied on Thu, Sep 15 2016 8:37 PM
leosgonewild:
Return process is realy quick. Did you try an software update?
leosgonewild
Helsinki, Finland
Posts 2,373
Got a new pair brand new in box Smile
Duels
England
Posts 2,553
Duels replied on Sun, Sep 25 2016 8:40 AM
Good luck with those Leo.
Roger
Norway
Posts 417
Roger replied on Sun, Nov 6 2016 2:55 PM
My H5 charger has been acting up (like draining the battery, not charging it) until last week - then it just stopped working at all. Anyone else experienced this? Will return the charger tomorrow.
Roger
Duels
England
Posts 2,553
Duels replied on Sun, Nov 6 2016 4:53 PM
Roger:
Roger
No. Mine works fine. Sorry to hear about your problems.
Aussie Michael
Melbourne, AU
Posts 3,730
mine are ok
The only issue is that i still cant run with them comfortably - they keep falling out no matter which of the tips i put in. :-( so its back to the old A8, or i whatever theyre known as now
Roger
Norway
Posts 417
Roger replied on Mon, Nov 7 2016 10:27 AM
@Michael - only way I can run with them is by putting the cable over my ears (https://www.youtube.com/watch?v=smbU2_zjIIs)
Returned the charger today - as it is a Beoplay product I had to return everything. Hopefully a replacement will be along shortly, as my iPhone 7 needs BT headphones (I know, the dongle - but my armband only has a hole on one side for the earphones, not able to run a lightning adapter through it). And now that I have received the Apple Watch Nike+ I'm so happy to be able to leave the phone behind, as the H5 and Apple Watch works very well together - except that I have to move the watch from my right arm to the left arm due to reception issues (I guess the BT receiver is in left earplug?)
Roger
Duels
England
Posts 2,553
Duels replied on Mon, Nov 7 2016 10:42 AM
Aussie Michael:
mine are ok
The A8. That I would like to see Michael Big Smile
hemenex
Posts 569
hemenex replied on Mon, Nov 7 2016 2:32 PM
@Duels: Newbie Stick out tongue
Probably those: https://www.beoworld.org/prod_details.asp?pid=764
Anyway, nice idea... Big Smile
Duels
England
Posts 2,553
Duels replied on Mon, Nov 7 2016 4:12 PM
hemenex:
@Duels: Newbie
I know I know. I was just teasing.
jplante
Posts 1
jplante replied on Fri, Feb 10 2017 8:47 PM
Is anybody getting a loud vibration when there's high pitch instrument "trumpets or guitar" listening at high volume (in the bus)? The sound files I'm using aren't FLAC, but they are still coming from Apple Music. It doesn't sound like a distortion, but rather a mechanical vibration like if a piece was loose.
Is this vibration the normal way the headphone reacts to badly recorded music? It's the same kind of "jitter" you are describing in the left earplug.
I love my headphones, but it's really annoying.
leosgonewild
Helsinki, Finland
Posts 2,373
I don't think anything can be loose inside. I open mine up, and the amount of glue used on the H5's doesn't leave anything to be loose Big Smile
Page 1 of 1 (15 items) | RSS
