Controlling Motorised stand
This post has 3 Replies | 0 Followers
BenSA
Durban, South Africa
Posts 1,404
BenSA Posted: Wed, Sep 14 2016 12:37 PM
Hi
There is no "stand" option on my Beo5. I have been in the config tool and there are no "stand" options that have been hidden. How do I control the motorised stand?
I did post this on the Beo5/6 page but no one replied so I am hoping I shall have better luck here. I couldn't find an answer either searching the forum.
Ben
Opman
Wilmslow, Cheshire
Posts 443
Opman replied on Wed, Sep 14 2016 1:00 PM
Hi Ben
From memory you select the stand option when configuring which products you are using. When you pick the tv there is box below that selection where you tick which tuner you are using and whether or not you have a motorised placement. Once this is ticked, the finished configuration will default to give you control of the stand.
Opman
BenSA
Posts 1,404
BenSA replied on Wed, Sep 14 2016 1:10 PM
Thanks Opman....I had selected the stand but I deselected it and selected it again and it worked all of a sudden. Must be good vibes coming from you that made it work. In any case thank you for replying!
Ben
Opman
Wilmslow, Cheshire
Posts 443
Opman replied on Wed, Sep 14 2016 9:56 PM
Hi Ben
Result :-) glad to hear you got it working.
Thanks for posting, always nice to hear that you have helped someone.
Regards
Opman
Page 1 of 1 (4 items) | RSS
