I'm becoming frustrated with my newly bought Moment. Initially Deezer playlists were loaded and would play, but since then newer playlists created on my Mac or iPad do not appear on the Moment. However they can be played on it through the iPad!
Does anyone have this happen or know how to sort it. I have set back to factory settings but still the same.
Don't despair - a fix is on the way - eventually...
Here's the thread relating to the topic.
http://archivedforum2.beoworld.org/forums/t/21473.aspx
Right now, the only less than ideal workaround is to add music to your existing Deezer playlists that still show up on the Moment -or- failing that, play your music via Deezer from the BeoMusic App to the Moment.
