Hi.
I control my Beoplay A6 via the Beomusic App, in the menu there are different sources to choose from, one of them is IOS. When i choose that I can see my music in iTunes from the computere (iMac) but alle the songs are "trunked", gray, and can´t be played. What is wrong?
Brgds Mogens
BeoNut since '75
you can only play the music which is on your device, the rest is grey as with iTunes Match. you can stream your library via Airplay from your iMac to the A6
Wohnzimmer: BeoVision Avant 55", BeoLab 11, 12-2 und 12-3 für 5.1-Sound + appleTV 4K und Philips BluRay-Player; BeoSound 2, BeoSound 3000 (fast nur noch Deko)////Schlafzimmer: BeoEssence MkII, BeoLab 4000 + Samsung 46"-TV////Büro: BLC NL/ML, BeoSound 35, Thorens TD320MkII, Samsung 32"-TV, WesternDigital 4TB-Server////Bad: BeoLab 2000; alles CAT7 verkabelt////Küche: M5 (drahtlos) plus diverse apple-Geräte (imac, macbook, ipads, iphones, timecapsule, watch)
sorry, i was too impatient with my iPad
sorry, i was still too impatient with my iPad
next time i´ll be waiting a bit longer
Thanks for your replies.
The music is copied from CD´s but I subcribed to iTunes Match once but unsubcribed again after 8 months. Maybe the matching of my libary did something regarding the rights to my music? It is the same with iMusic. I see the playlists on the Beomusic App but cant play them.
Brdgs Mogens
