How do i connect 2 junction boxes? Does link rooms get to go on the second box even using the video and audio master ports even if they are not masters?
Thanks you for any help.
Assuming you're takinkg about a ML-DISTRIBUTION-BOX with 6 ML-SOCKETS.All 6 sockets are in parallel, all them can be used for any purpose (Audio--Master / Video-Master / Link-Room)The lables are just a little help to distinguish the cables.
Use a standard ML cable to connect the 2 distribution boxes.
Great! this eases the setep re-do i'm planning. thanks.
