Present: BL90, Core, BL6000, CD7000, Beogram 7000, Essence Remote.
Past: BL1, BL2, BL8000, BS9000, BL5, BC2, BS5, BV5, BV4-50, Beosystem 3, BL3, DVD1, Beoremote 4, Moment.
Mr 10Percent:Most DIYAudio-ers ( there is a forum out there) would follow the basic 5-point fool-proof plan 1. Immediately poo-poo B&O, BL5 and BL90 as all form and no substance and you could do the same yourself a lot cheaper. 2. Talk themselves into circles eventually forgetting what the original question was. 3. Agree to coat the whole living room in black egg-crate acoustic foam and put the uni-directional copper-free copper cables on little chess pieces to isolate it from something, 4. Talk themselves into tighter circles and all disagree on everything. 5. Forget where the door to the living room is because they covered it all in black egg-crate acoustic foam. In summary, I would buy a nice rug, nice curtains, some large artwork which you wife would appreciate and enjoy what you have over a large bottle of red.
I'm going down the same path, exploring options at this stage. I have BL5s with BL3 surround and I can't afford to upgrade to BL50/90. So looking to see if I can (or even if I should) improve the room acoustics.
Room description: 7.3m by 6m by 2.4m high. Wood floors, lots of wood bookcases, grand piano, hard leather sofa, fabric sofa, full length curtains along one wall. Two large openings (doorways) with no doors. Measured acoustic reverb at around 0.45 to 0.55 across all frequencies. Apparently the desired reverb is 0.30 for home theatre.
I'm looking at panels by ArtNovion (https://artnovion.com/design scroll down for images) mainly because they look quite good and are easily affixed to the wall and ceiling. They have an app (iPhone or iPad only, unfortunately) that can measure the current acoustics of your room. Since I used an iPad internal microphone the results aren't particularly accurate at very low and very high frequencies but it gave me an idea of what the problem areas might be. You can then add panels to the app and predict how the room acoustics change.
What I'd like to know is: with the ARC in the BL5, how does this affect the necessity or design of room acoustic treatment?
BV6-26, BV7-40, BL7.4, BL3, BL5, BS9000, BC1, ES1, Beo4, BeoPort
