Hello :-)
I recently bought a Beogram 8002 and a Beomaster 8000.
I am now searching for the perfect speakers for the best old fashion sound.
I have listened to Beovox M100 and Beovox MS 150-2.
Now I am considering Beovox M75 and Beovox 5700.
Any advice would be sincerely appreciated.
Regards
Niklas
Do you know the Beovox 5700? The salesman (?) tells me, that they er very good. Maybe even better than the M100 and the MS-150.
Thank you very much!
Thanks a lot!
I had 5700's years ago and was pleased with them, however the Beovox Penta's sound much better, although any set of Penta's unless refurbished will need more work to restore than 5700's.
Personally on this journey of trying different B&O systems, the Penta's are still my favourites - just swapped out my BL8000 back for the Penta and the difference is amazing, that said I prefer the look of the MS' but have never heard them
The big passives have more detailed bass than the Pentas which have to rely on multiple small drivers - I do like the mid-range of Pentas though. I ran my 8000 through both MS150s and M100s. I preferred the M100 though the MS150s were excellent.
Peter
