Beo4 LCD replacement
This post has 4 Replies | 2 Followers
Saint Beogrowler
Saint Paul
Posts 780
Saint Beogrowler Posted: Tue, Oct 4 2016 12:00 AM
The LCD screen in the BEO 4 is super easy to replace. Here are picture showing it.
4 screws.
This is what you'll see.
3 braces with 2 nuts each to remove
Rotate and remove LCD screen by gently lifting
Side view
What you'll see after you life the screen, remove the old foam
Foam gone
New included pads in place
Instructions
Old LCD below new one to be added
Strip lined up to be aligned with the connections, no dust or grease allowed here
Rotated PCB on to screen
Reassemble
Enjoy large screen single line display
Now I just need to learn to to operate my MX5000 with the Beo4
Saint Beogrowler
Saint Paul
Posts 780
Lift vs life
Stripe vs strip
Beobuddy
Utrecht, The Netherlands
Posts 3,972
A MX7000 type 78xx or higher is suited for the BEo4.
Most instructions are the same for the BL1000 (originally for the MX5000) and Beo4. But turning the stand with the arrow buttons will respond different or not. Play will be Go, The coloured buttons will not work. (these are SHIFT + Arrow if I remenber correctly)
Guy
Warwickshire
Posts 2,590
Guy replied on Fri, Oct 7 2016 4:01 PM
Great thread with clear photos Peter - many thanks for taking the time to post.  I've done this process several times but never thought to document it for the benefit of others, so all credit for making the effort!   I've never worn gloves, but probably should!
Nikonitis
Posts 1
Hi, I appreciate this is a bit old but I wonder if you might be able to help. I have suffered the same fate as many other with a now non working Beo4 remote. I have attempted, using your images, to open up the back of the remote but I simply cannot get the 2 halves part and I suspect I might end up doing more damage than good trying. The little press stub at the top of the remote moves slightly but nothing else happens. I have tried prising it apart but I simply  don't know where to apply pressure and could break something. Any advice would be appreciated?
Page 1 of 1 (5 items) | RSS
