BM3400 dial lamp
geearr
Posts 16
geearr Posted: Tue, Oct 4 2016 10:29 AM
I have removed the indicator assembly (picture attached) and now want to change the light bulb.  Can anybody advise me of the easiest way to change this globe before I start pulling it and breaking something.  At the moment everything seems tight and doesn't want to move.
Thanks for any assistance
Regards
Geoff
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Tue, Oct 4 2016 11:08 AM
Grab it with pliers, twist and pull.
The glass envelope will almost certainly break and you can then drill out the remains of it.
Working inside a clear plastic bag will catch all glass debris.
geearr
Posts 16
Thanks for your help Martin - much appreciated.
I gave the the light bulb a pull and a twist and it broke as expected.  The plastic bag idea worked very well.  I didn't like drilling into an area that I new nothing about but persevered slowly and carefully.  I then noticed that the long part was starting to move and with a bit of coaxing it pulled out of the black lamp holder.  The photo attached gives a better idea what is inside the assembly.  The lamp hole is inside a clear plastic part - now looking decidedly opaque so the next step will be to clean it out and hopefully let some light through.  The lamp sizes I have are 5mm diameter so the aim is to end up with a 5mm clean hole.  Could be a tough one this time - it does look a bit of a mess after 40 years of over-heating.
Regards
Geoff
Page 1 of 1 (3 items) | RSS
