Classic Beograd 4000 has no tension on the tuning slider, having removed the cover I can see the twine and two plastic prongs but can see how the prongs attach to the twine?
Any assistance would be appreciated
Welcome to Beoworld !
Zig-zag the dial string between the prongs and place a drop of glue to keep it there.
Oh, - and Beograd is a city.
Damn autocorrect, thanks for the reply, anyone have a picture of how it is supposed to be fitted/secured. I have searched google images without success
Here a pic of mine, 1 prong was broken, so I just glued the the string to the last one, Find a station with known MHz, adjust the scale to same, put the string over one prong (tap) and under the other then put a drop of glue on it use epoxy or an all round glue. here a link to my BM 4000 restoration.
Thanks, has anyone got a picture of how is is supposed to look?
Thanks Martin. Managed to scissor the twine between the two prongs and it works fine.
