Is there a way to restore the brushed aluminum finish?
This post has 3 Replies | 0 Followers
Fatandre
Posts 43
Fatandre Posted: Tue, Oct 11 2016 12:22 AM
i have some speakers that have light scratches on them
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Tue, Oct 11 2016 6:17 AM
The short answer is no.
You cannot restore the original surface unless you have an aluminum plant like Bang & Olufsens.
And it's not brushed, it's eloxated and has a protective coating on top.
vikinger
Vestri Kirkjubyr, UK
Posts 5,422
vikinger replied on Tue, Oct 11 2016 9:46 AM
I asked a similar question about a Beogram platter when I first joined Beoworld, and got no answer.
You can't repair existing damage but you may be able to prevent any aluminium oxydation from spreading or 'tracking' across brushed aluminium. Try using 'Renaissance' micro-crystaline wax polish. It is used by museums for all sorts of protection and restoration and leaves an invisible coating.
www.plcreator.co.uk
Graham
Fatandre
Posts 43
Fatandre replied on Tue, Oct 11 2016 12:05 PM
So there is no way to mask little sand scratches.
 They are on my CX100 on the bottom and its just those little things that annoy me.
You cannt actually see them, but if I can fix it I would want to
Page 1 of 1 (4 items) | RSS
