WiFi / WISA signal in long house
This post has 6 Replies | 2 Followers
Chris Harrison
Peak District
Posts 381
Chris Harrison Posted: Sun, Oct 16 2016 9:44 AM
Having issues with a router at the moment as the signal will not reach around the new house. I am very tempted to buy a Horizon for one end of the house. Will the WISA signals extend to the other side of the house via a standard WiFi extender? Any suggestions before I buy something is much appreciated.
Thanks.
Beosound 8, Beotime, Beocom 4, Beo 5, Lutron Rania, MacBook 15" (Mid 2015), iPad Pro, iPhone 6S, B&O Play H3, Beolit 12, Form 2, A8 Headphones, B&O Play A1, B&O Essence
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Sun, Oct 16 2016 9:59 AM
I don't understand what you want to achieve here ? Do you want the sound of the Horizon in one house to extend to speakers in another house leveraging WiSA ? IT means that you'll not see what you hear in the place hosting the speakers, correct ? In this case Multiroom is the solution I think.
WiSA cannot be extended with standard Wifi extenders.
Marcello
Posts 213
Marcello replied on Sun, Oct 16 2016 10:01 AM
Can you clarify your issue?
If you need to link the TV to your wifi network, then a network extender will work. But if your issue is related to the wireless connection between your tv and its external speakers (Which uses the Wisa standard), it has nothing to do with wifi.
Chris Harrison
Peak District
Posts 381
I was hoping to play something like Spotify from the Horizon to WiSA compliant speakers around the house.
Michael
Sweden
Posts 2,578
Michael replied on Sun, Oct 16 2016 10:39 AM
Chris Harrison:
Beosound 8, Beotime, Beocom 4, Beo 5, Lutron Rania, MacBook 15" (Mid 2015), iPad Mini, iPhone 6, B&O Play H3, Beolit 12, Form 2, A8 Headphones.
No - WISA does not extend. You would have to buy a transmitter one then and connect it through power link from your tv to get longer range.
Nothing I would recommend.
elephant
AU
Posts 8,219
elephant replied on Sun, Oct 16 2016 11:50 AM
Chris Harrison:
I think one or more Essences are your possible unpalatable answers
BeoNut since '75
StUrrock
Posts 995
StUrrock replied on Sun, Oct 16 2016 8:36 PM
WISA is only for short range and mainly for DIY install.
For larger houses/ranges or places where there are many competing wifi networks wiring is the only way to go.
Page 1 of 1 (7 items) | RSS
