I have in one room:
A Beovision Avant55 with a BeoRemoteOne
A Beosound Essence2 with Beolab 5 connected.
The Essence is NOT integrated with the Avant because then I cannot use Spotify.
Now I would like to be able to control the volume etc of the Essence also via the BR1. Is this possible? Should I then connect an IR eye to the Essence?
How do I then switch on the BR1 between controlling the Avant or controlling the Essence?
Thanks.
- Flere
smile and enjoy the moment
Found part of the answer in the FAQ
http://bogo.custhelp.com/app/answers/detail/a_id/13309/kw/beoremote
On how to control the Essence2 if you have an IR eye connected.
Found it.
The answers are in the user mauals of the Essence2 and the BR1.
Flere:Found it. The answers are in the user mauals of the Essence2 and the BR1. - Flere smile and enjoy the moment
BeoNut since '75
elephant:Thanks for the thread and the BR1 link - was there a separate Essence Mk 2 link ? BeoNut since '75
Flere:No, just the manuals and that one link. - Flere smile and enjoy the moment
