Has anyone ever got the PS4 to work on Beovision 7-40 MK2-HD?
alfiehere
Posts 3
alfiehere Posted: Fri, Oct 21 2016 1:55 PM
Just would like to know if anyone has done it !! ?? :(
kallasr
Germany
Posts 2,562
kallasr replied on Fri, Oct 21 2016 6:40 PM
Make sure you set the resolution to 720o and 50 or 60 Hz (cannot remember which one is correct). The it will work just fine using DVI and digital sound in or via Scart.
Ralf
alfiehere
Posts 3
alfiehere replied on Fri, Oct 21 2016 8:38 PM
Thanks, how do you change it to 50 or 60hz? then what cables if want to use hdmi
kallasr
Germany
Posts 2,562
kallasr replied on Fri, Oct 21 2016 9:13 PM
Hdmi to dvi cable for picture plus sound as described.
You need to attach it to another TV to set it up.
Ralf
Page 1 of 1 (4 items) | RSS
