Beovision 11-55, BeoPlay V1 40, Beosound 9000, Beolab 8000's and 3 Beocom 5's...
And what would you want it to connect it to?
Gennaro:Can't seem to connect with my wifi??? I have Verizon FIOS Any advice?
It is only the Beomusic app which can not connect to WiFi?
If so - Just stop the Beomusic app completely (even not running in back ground)
Goto iOS settings; Beomusic; choose clear cache; restart Beomusic.
Or restart your device completely
Millemissen: And what would you want it to connect to? MM
I see in your list no compatible devices.
Millemissen:I see in your list no compatible devices. MM There is a tv - and there is a BV.
You'll need a NL-audio device to use the app.
Once you have this, you can let your NL-video devices join-in to the music via the multiroom screen of the app.
Millemissen:You'll need a NL-audio device to use the app. Once you have this, you can let your NL-video devices join-in to the music via the multiroom screen of the app.MM
Correct.
And note: the app is WiFi connected; so no correct info
@Gennaro
If you a looking for the (iOS) app to control your tv's, this is it:
https://appsto.re/dk/rb_xF.i
