How do I change positions of items in the list menu?
Press the red dot and list at the same time
Then press list until "Move" is displayed
Then Press Go
Then press list until the function you want o move is displayed.
Press Go and that function will be moved to first in the list.
But note that older Beo4 firmware versions don't have the MOVE function. Then you need to remove everything and add them back in your preferred older.
--mika
Thanks. It worked!
