Hi!
I am an original owner, bought in 1984 or so, Beogram 5000. Recently reunited with it., as I left it with my father in 1989.
The bulb and bulb holder were missing. I have reconditioned the turntable with a replacement belt, motor and stylus and also bought another in much better condition that just needs a stylus.
I would like to find a lightbulb for the original turntable. The only mark on the other bulb is 12V.
Can someone direct me to a source for the bulb?
Thank you!
Update!
I ended up buying another Beogram 5000 that had the parts, then copied them and printed them! I now have 2 fully functioning Beogram 5000 turntables.
Very clever - and very nice deck - the 5000 was superior sonically to the 5005 that replaced it - a beautifully made deck - well done for getting it back on its feet.
Peter
Hello
I was looking on internet for exactly the same piece for my Beogram, it seems that is missing on mine, and i found this page and your amazing job.
Can you please help and send me a 3d model for print of that part, if possible ? I am also having the exact problem with the bulb that is burned or something. Dis you find a replacement ?
my e-mail:
george_ursache@yahoo.com /
george.ursache@gmail.com
I know this is an older post, hope you will see the message.
Thank you,
George
I can supply the lamp.PM or email me.
Yes, i am interested. Is it a special lamp or can i replace with something similar ? You can reply directly on e-mail (above) Thank you
I know it’s an old post but hoping someone can help, does anyone have a spare hinge cover they are willing to sell or if you have the 3D file for the hinge cover they are willing to share? I recently bought this lovely turntable but sadly the hinge cover is missing.
