hi,
just completed Integrating my ML system using a ML Gateway, a Raspberry Pi running Domoticz and an Amazon Echo Dot . With this combo, I can voice control any MLGW connected device in the house with simple commands like "Alexa, turn on the main TV" etc.
Useful? Maybe - but it is cool.
frog: hi, just completed Integrating my ML system using a ML Gateway, a Raspberry Pi running Domoticz and an Amazon Echo Dot . With this combo, I can voice control any MLGW connected device in the house with simple commands like "Alexa, turn on the main TV" etc. Useful? Maybe - but it is cool.
If it doesn't work, try "et tu, Brute"
What happens when you say "Tea, Earl Gray, hot" ???
Jeff
I, too, have been using IFTTT triggers to control my BLGW by voice commands to the Echo. It would be nice to see the BLGW gain the ability to interact with the Echo directly without IFTTT. I can also elect music from Spotify by voice commands to an Echo Dot paired with a BeoPlay A2. For choosing music from my iTunes library, I can speak the selection into my Apple Watch to control an iPhone paired with a BeoPlay speaker or for Airplay to an airport express connected to my BeoSound.
What we need now if for all of these parts to be connected into one simple system.
Jeff: What happens when you say "Tea, Earl Gray, hot" ???
It calls the movers, get your stuff put in a truck, and ships you and the stuff to UK ;)
/Weebyx
It says that it isn't a replicator :0
I don't use IFTTT as I find it a bit clunky. The bridge code between the Alexa service and the MLGW is here just for interest (Python running on the Raspberry - same as Domoticz).
#!/usr/bin/python import socket # Import socket module import time # Import Time module for delays import sys import getopt Debug = True # Setup B&O datagrams if Debug: serno = '01390000'.decode('hex') MLNDict = {'BS3':'01','BV10':'02'} MLNDevices = {'AppleTV':['85','00'],'Sky':['8A','00'], 'Radio':['81','01'], 'CD':['92','01']} def buildMLString(device,status,source): MLString = '01010300' if Debug: print (MLString, device, status, source) if status == 'Off': return(''.join((MLString,MLNDict[device],'000C00'))) return(''.join((MLString,MLNDict[device],MLNDevices[source][1],MLNDevices[source][0],'00'))) s = socket.socket(socket.AF_INET, socket.SOCK_STREAM) # Create a socket object try: hostname = ("192.168.0.22") # Masterlink Gateway hostname host = socket.gethostbyname(hostname) # Connect to Mlgw.local port = 9000 # Reserve a port for your service. if Debug: print "Connecting to: ",host, port except socket.gaierror,err: print "cannot resolve hostname: ",hostname,err s.connect((host, port)) if Debug: print ("Connected") # Sending Serial Number Request print "Sending Serial Number Request" s.send(serno) print s.recv(255) MLString = buildMLString(sys.argv[1], sys.argv[2], sys.argv[3]) if Debug: print MLString s.send(MLString.decode('hex')) s.close # Close the socket when done
#!/usr/bin/python
import sys
import getopt
Debug = True
if Debug:
if status == 'Off':
try:
print ("Connected")
s.send(serno)
print s.recv(255)
print MLString
beojeff:I, too, have been using IFTTT triggers to control my BLGW by voice commands to the Echo. It would be nice to see the BLGW gain the ability to interact with the Echo directly without IFTTT. I can also elect music from Spotify by voice commands to an Echo Dot paired with a BeoPlay A2. For choosing music from my iTunes library, I can speak the selection into my Apple Watch to control an iPhone paired with a BeoPlay speaker or for Airplay to an airport express connected to my BeoSound. What we need now if for all of these parts to be connected into one simple system.
I got an email the other day pitching me on Harmony remote / Alexa integration. I use a Harmony remote to control my BV8. Supposedly, this is is another path if one doesn't want to tinker with BLGW, IFTTT, etc.
Stan
Just finished the integration. Whole home integration with voice. It is a handy second method of controlling most things. Using general purpose open-source home automation software is a cheap and extensible way of getting there.
https://m.youtube.com/watch?v=H5SFppTW_qM
Kind of cool.
Please keep us posted, how you - in the long run - prefer to 'control' the tv?
Voice contolliing or remote controlling?
Can you do more, than what you showed?
If you live with a family - what do they think/prefer?
Voice controlling or remote controlling?
Millemissen:Kind of cool. Please keep us posted, how you - in the long run - prefer to 'control' the tv? Voice controlling or remote controlling? Can you do more, than what you showed? If you live with a family - what do they think/prefer? MM There is a tv - and there is a BV.
BeoNut since '75
Hi Frog,
Looks good, can you control which source is selected via Alexa or change channel?
Think I will have to try this over the Christmas break.
The controls are limited by what Alexa will recognise (although the MLGW though can really do everything and more that the remote can), so channel up and down are OK, but say asking to go to a particular channel number is problematic unless you have set that channel up as a macro.
if you only want to control one TV, an easier route is to use the Logitech harmony hub which sends control info via IR and doesn't need the MLGW. It already has an Alexa app (a 'skill') but It is more expensive though if you have the MLGW already. It also has similar Alexa recognition limitations.
As usual I am playing catch up and suppose that your Alexa/BEO system has evolved still further. Any recent updates?
Shadowing you I have an underused MLGW and plenty of B&O hardware throughout the house.so am quite envious of what you have achieved.
This Christmas I have bought the missus an Amazon Echo Show and the kids Echo dots so they can chat to their hearts content. So on Christmas morning I will have the stuff hopefully that will allow me to do some home automation.
Would it be possible for you to give me a shopping list of other hardware I need to emulate your set up, i.e. Raspberry Pi etc and where I stick your code etc.
Cheers
Gary
Sure, no problem.
i recommend a raspberry pi 3 (£35) (with the extras you need; SD card psu), a RFXCom RFXTX433e (£80) (useful for controlling 433Mhz devices), Domoticz software from www.domoticz.com (open source) and you should be good to go. To link to Alexa, you can either use Controlix (which has a small annual charge) or build your own skill - both options are in the Domoticz forum. I’d suggest using Controlix as it would be very simple to set up. You can set up switches in Domoticz which would link to the MLGW so that Alexa can switch on and control various B&O devices.
In terms of new software, there haven’t been any changes to the code as it works reliably and I haven’t had any need to change it.
Having said that, there are changes to the code tat make it more functional, but this forum is absolutely rubbish for posting code segments. I’ll see about setting up a Dropbox location for two pieces of code tat you could modify.
Hi Frog, I'm thinking about getting a used MLGW to allow me to control my z-wave lights from the remote through http json requests to homeseer as well as hue lights to the bridge in the same way, which I gather can be done with custom strings. What I'm also interested in though is feeding my hikvision IP camera on the porch through to the gateway which has an MJPEG stream and be able to bring up the video feed on my beovision 11 which apparently has a 'home control' menu. I've not come across this in the menus so I presume it activates automatically when a gateway is present on the network, but do you know if the MLGW is compatible with this BV menu or whether it needs the newer BLGW to do this? I thought I'd ask as that looks like a BV 11 in your alexa demo youtube video together with the MLGW :) Many thanks! Rob.
