Beosound Century line out -where ,how to ?
marexy
Posts 710
marexy Posted: Thu, Oct 27 2016 12:04 PM
Hi :)
From my BS Century want to mount connector for line out.
want to connect up  active woofer or amplifier.
I have tried to carry out signal from the headphone jack and the signal is distorted.
Please advise if someone allready done that ?
Thanks for all opinions.
marexy
Posts 710
marexy replied on Fri, Oct 28 2016 12:43 PM
Nobody done it ?
Iti will be nice to add some active woofer to it :)
Guy
Warwickshire
Posts 2,590
Guy replied on Fri, Oct 28 2016 1:27 PM
I don't have a century and haven't tried.
However, you may well be able to use the DIN aux socket at the back.  The set-up manual says that this is an AUX input only, however if you look at the circuit diagrams, then PINs 1 and 4 appear to be AUX out at line level.  All these manuals are available on site to silver and gold members.
Hope this helps!
Guy
Warwickshire
Posts 2,590
Guy replied on Fri, Oct 28 2016 1:30 PM
I would buy something like this, so you can use both an AUX input and the line output (if it works) at the same time: https://www.amazon.co.uk/Male-Phono-Plugs-Audio-Cable/dp/B008N29OSG/ref=pd_cp_107_2?_encoding=UTF8&psc=1&refRID=5VTF851WZYEJ2V84FKSW
Page 1 of 1 (4 items) | RSS
