Hello, I have just bought a B+O 5000 set and wanted to know does anybody have a manual for the Master Control Panel. I have fitted new batteries, however control does not light up, is there an on/off switch? Many thanks. Ben.
No on off switch - should light up when you use any of the keys - I suspect a loose contact in the battery box in the first event.
Peter
