I miss my old DAC power amp...I had it connected to my mac and my turntable. I could play vinyl (what I mostly listen to at home) and music files on the mac too. I wondered would a B&O Moment pair well with a Beogram 8002? And how would that all work if at all with Beovox 3000 flat speakers? I basically would like to ditch the notion of having a power amp in the loop. I love vinyl and the freedom of my digital files. I'm currently running the 8002 through a BM6000 but none is connected to my digital music.
I've even considered a Beosound 2 360 speaker as my living room is only about 18 m/sq and ditching the Beovox's as the cables have always been a sticking point with my wife.
Beogram 8002 + B&O Moment + Beosound 2 ????
Hi etype76,
No problem! You can easily play the Beogram 8002 into the Moment by adding a pre-amp to boost the signal: http://soundsheavenly.com/beogram-record-players/12-pre-amp-bundle-for-bo-beogram-and-all-turntables.html
The other option is to keep the Beogram with the Beomaster 6000 and link a Sonos Connect (or similar digital music streamer) to the Beomaster with this cable to access your digital music: http://soundsheavenly.com/bang-olufsen/52--2rca-5pd-.html
The Beovox 3000 speakers will connect directly to the Beomaster, but to use them with the Moment you would need to add either Beolink Passive or a power amplifier.
Kind regards, Steve.
Steve.
www.soundsheavenly.com
A BeoSound 2 would be more than perfect for that size of room.
And it has a line-in for your BeoGram too.
Just add the small preamp, that Steve mentioned.
Millemissen:A BeoSound 2 would be more than perfect for that size of room. And it has a line-in for your BeoGram too. Just add the small preamp, that Steve mentioned. MM There is a tv - and there is a BV.
Would love to see a pic of that combo!! 😀
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
They look very nice together - you would never guess how many years separated the Beogram and the Beosound unless you knew your B&O products well!
