Stuck Transport Screws
This post has 6 Replies | 0 Followers
WhatsGoingOn
Posts 44
WhatsGoingOn Posted: Sat, Oct 29 2016 11:56 PM
Hi all,
I have a Beogram 9000 and two of my transport keys are "stuck". By "stuck", I mean I can screw them and they will tighten into transport mode but will not go wobbly and loose like they are supposed to. One of them does. This means that one corner of the platter is a few mm higher than the other, and I'm pretty sure this is what is causing the inner-groove distortion I've been experiencing.
How do I "un-stick" these screws? I can't unscrew them from under the platter as the screws are on the bottom of the unit. Thanks!
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Sun, Oct 30 2016 12:24 PM
You will have to open the deck and have a look inside to see WhatsGoingOn. Laughing
WhatsGoingOn
Posts 44
Haha nice! It's named after the Marvin Gaye album, actually Embarrassed
I did look inside and couldn't see anything that could have been blocking it... Any ideas?
MediaBobNY
Greenwich Village, NYC
Posts 1,106
WhatsGoingOn:
Of course you can.  Have one side held up by the edge of a table and hold the other side up with your hand.  With your other hand loosen the screws from the exposed bottom.   It takes a lot of loosening before they go wobbly - I don't think you loosened enough.
Dillen
Posts 13,191
Dillen replied on Mon, Oct 31 2016 6:16 AM
The "nuts" inside can break from their holders.
It can result in the above symptoms.
WhatsGoingOn
Posts 44
MediaBobNY:
WhatsGoingOn:
Thanks, funnily enough when I checked today it was wobbly. I may try and make it more so, but I'm not sure if that's what's causing the platter to be uneven. The platter sits about 2-3mm higher on the side which has the stiff screw. Any ideas? Thanks for your help.
WhatsGoingOn
Posts 44
Dillen:
OK, do you know of any ways to fix this? Thanks!
Page 1 of 1 (7 items) | RSS
