Hi all,
Does anyone know where I can get a good quality right angle DIN plug to connect my BG4002 into a Beomaster 2200?
There are plastic/nickel plated ones out there but I can't find anything of decent quality.
Because of the hinged flap arrangement on the BM, there is insufficient headroom for the normal type of plug.
Thanks,
Perhaps:
http://www.ebay.co.uk/itm/Angled-5-Pin-Din-Switchcraft-05DL5MX-Adjustable-angles-/172121080569?hash=item28133742f9:g:lx4AAOSwwpdW2CEM
Well spotted.
Thanks.
Simon
