Hi
Just came in a beocenter 9000, but looks like when opening some hands that do not know what they do have been inside.....
I have cleaned and grased the opening panel but when testing they work but not the right way.
They both open at the same time when pressing on the CD sensor....
Looks also that the tape panel motor is kind of tired, did thid happened already to some of you guys ???
Must be something funny as when plug it out and in the outlet both tape and CD panel are running.
After some research the Tape Panel only goes the open way.
Any solution...
