Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
According to manual...
Red flashing fast : Battery capacity below 2% (will soon switch off) / Hardware error
Very sad the the units fail so soon..
/Weebyx
Poh poh poh... I hope that they will not reproduce the bad BeoSound 3 experience.
I'll wait more to see if it's an isolated bug or if other units fail before ordering a BS2.
Hiort:Dealer said had the same problem with their first unit. Recommended me to drain the battery fully. I will do that, since it still can play. Keep you posted.
Keep you posted.
Did it restart properly after battery drain?
The BS1 was off when I came home last night, after being on for the night and the full day. It could be that my wife shutted it down in the evening.
I plugged it into mains and the white light came on. I checked battery status in Beosetup app and it was 8%.
Now the red light is gone and it behaves as it should.
Problem is back. Red light blinking. When I remove mains it goes dead.
I will take it back to dealer.
batteries, batteries, never trust poor batteries.
That's for this I would prefer a besound 2 than a beosound 1.
4 beolab 5, beolab 9, beolab 10, beolab 5000, beolab 8000 mk2, beolab 6002, beolab 3500, beovision 7 55 mk2, 2 beovision 11 46 mk4, beotime, beosound ouverture, beosound essence, beoplay A8, beomaster 900 RG de luxe and the collection continues...
Hope this will work at it should
BeoVision Haermony 65"...BeoLab 28 Anthracite....BeoLab 17 as REAR....BV10-32....BC6-26....Beosound 9000....Beosound 1 New York edt....Beogram 4002....Beoplay Emerge....Beoplay M5....Beoplay M3....Beoremote Halo....BeoRemote One BT....Beo6....Beo4....Beo4 Cinema....BeoLink 7000....Serene....H95 Black LTD....H9i Rimowa....6 x H6....Form 1....U70...
