Hi
I have just bought a BV5-42 MK3 for aprox 200€. I have a Beosystem 2 with VGA and two HD cards for the screen.
My intention is that I shall change the main chassi and the screen in Bv5 to the newer from BS2 so BV5 has one VGA and two HDMI connection
I have come so far that I have sorted out most of the connection. The to chassi is not 100% the same.
So there is not the same connection for the fan.
Maybe everything will totally crasch
I will keep you posted.
BeoVision Haermony 65"...BeoLab 28 Anthracite....BeoLab 17 as REAR....BV10-32....BC6-26....Beosound 9000....Beosound 1 New York edt....Beogram 4002....Beoplay Emerge....Beoplay M5....Beoplay M3....Beoremote Halo....BeoRemote One BT....Beo6....Beo4....Beo4 Cinema....BeoLink 7000....Serene....H95 Black LTD....H9i Rimowa....6 x H6....Form 1....U70...
Completed!!
With two HDMI on each side!
mr_anders_son:Completed!! With two HDMI on each side!
StKong: mr_anders_son: Completed!! With two HDMI on each side! Very cool! Any side effects?
Very cool!
Any side effects?
Work like a charm
Very good picture for this age of TV-set
mr_anders_son:Work like a charm Very good picture for this age of TV-set
Very well done .Which panel you use ?
