BC9500 IR module really hot and 2-way diodes sending all the time ?
This post has 1 Reply | 0 Followers
Weebyx
Denmark
Posts 1,213
Weebyx Posted: Thu, Nov 17 2016 6:59 PM
Yet another BC9500 issue :)
I have fixed the source of the problem with the missing IR reception.
1: The IR unit was missing 25vac from power supply.
2: Someone had had problems with the unit before, and therefore disabled P98 over the relay.
3: This I now know is because when it works, the IR module is getting really really hot, and it is visible that the sender diodes is transmitting all the time. IR reception is not as sensitive as it should, but that makes sense with the diodes sending. 2-Way is not working either.
Has anyone seen this issue before ? It is not software since this is also happening with software from the 8500, which should not send any 2-way codes :)
/Weebyx
Weebyx
Denmark
Posts 1,213
Weebyx replied on Mon, Dec 5 2016 6:43 PM
Just to let you guys know...
The problem was the 4001 NOR gate IC, after this is changed, all is well again..
/Weebyx
Page 1 of 1 (2 items) | RSS
