Hey I removed the tape transport from 9300. And detached the golden wheel thingy on the bottom and turns out that the little rod retracts so I can't get the wheel back on without getting to the other side of it. However I can't for the live of me figure out how to get to it. Is there somebody who can help me with the problem? This is the tape transport with 3 rubber belts.
You should not have taken the brass wheel off... If you are trying to change belts, then this thread will help you.
http://archivedforum2.beoworld.org/forums/p/13275/115112.aspx#115112
You just go down to where the tapedeck is disassembled. Open it up as described, and try to press the white wheel rod up into the brass wheel again.
/Weebyx
Thank you very much. I figured I was not supposed to a bit too late because I wasn't able to find a guide. So thank you!
