Hi
Is there a USB Bluetooth adapter for Beomaster5, to stream audio from external source?
The closest adapter I found offers line input - http://soundsheavenly.com/input/17--ufo202-.html
Please help
Since the BM5 has only a USB port that can be used for external devices, you will have to use a USB soundcard/analog to digital converter (the one in your link).
This has a port for an analog source - you can connect any device (means: also a bluetooth receiver), that has an analog output.
In short: you need the converter and a bluetooth dongle.
