I've been using the Terminal more than I thought I would, having control over volume is very handy. I have my Beogram 8002 connected via DIN cable. What do the blue coloured keys do at the bottom of the remote? The cable I have doesn't allow me to access these key's functions. What cable do I need to do this? and could I use << and >> to toggle between tracks on a LP remotely? There's also STOP and RETURN, surely stop would return the arm anyway? Are these keys for dual function with Beocord then?
They are for operating the Beocord. Later Beomaster did have the facility you want - a 5500 can move the tone arm. I no longer have an 8000 or 8002 so confess I cannot remember if the tone arm could be moved remotely - no doubt an owner will be along soon!
As you are a silver member, there is a manual (a very small multi-language one!) for the Beomaster 6000 remote on site.
https://www.beoworld.org/manuals_view.asp?pid=994
Peter
