Beomaster 6000
This post has 11 Replies | 2 Followers
markph
Posts 6
markph Posted: Tue, Aug 7 2012 1:44 PM
Hi ,
I was handed down a beomaster 6000 from my farther its fantastic, is it possible to run my ipod
through it,i have the bits to make up a lead 3.5 jack, cable and 5 pin din not sure which pins to solder to
and which port to plug into.
Regards
Mark.
BeoHut
Posts 482
BeoHut replied on Tue, Aug 7 2012 2:02 PM
It is just quite simple. You only need a DIN-plug (5 pins) and at the other side RCA or minijack. For a few dollars available at a cable shop or megastore. Then connect this cable to the Tape input of your beloved Beomaster. Enjoy your new Beomaster!
Just Google for din to minijack or rca and you will see the sample pictures.
For a better sound use for example the HRT iStreamer. Perfect digital sound!
chartz
Burgundy, France
Posts 4,171
chartz replied on Tue, Aug 7 2012 2:05 PM
Hi and welcome!
You can use either TP1 or TP2. No problem at all. You won't get a fantastic sound from your iPod (not real hi-fi) but it'll work if you can solder!
http://pinouts.ru/Home/DinAudio_pinout.shtml
Jacques
markph
Posts 6
markph replied on Wed, Aug 8 2012 2:10 PM
Thank you for your reply, can you tell me which pins i solder to on the 5 pin din.
Kind Regards
Mark.
markph
Posts 6
markph replied on Wed, Aug 8 2012 2:15 PM
Thank you for your reply i have the bits to make up a cable im not sure which pins to solder to..
What is the HRT iStreamer please.
Kind Regards
Mark.
Guy
Warwickshire
Posts 2,590
Guy replied on Wed, Aug 8 2012 2:21 PM
Does this help?  It's a std audiolink socket - ignore pins 6 and 7
http://www.beoworld.org/beotech/mclconn3.htm
markph
Posts 6
markph replied on Wed, Aug 8 2012 4:16 PM
I soldered the wires as per diagram just getting a humming noise,  when i touch the ipod it gets louder, think there must be something wrong with it.
Thank you for your help.
Kind Regards
Mark.
BeoHut
Posts 482
BeoHut replied on Wed, Aug 8 2012 9:05 PM
markph:
Kind Regards
Mark.
Hi markph,
In this link, http://highresolutiontechnologies.com/istreamer, you can find some information of the HRT iStreamer.
I use this one, and the HRT Streamer II for my computer, to play digital music. The quality is brilliant.
Hope this will help you.
Søren Hammer
Denmark
Posts 953
The Tape 2 input has RCA plugs - you'll just need a 3.5 mm jack -> 2x RCA.
Vinyl records, cassettes, open reel, valve amplifiers and film photography.
markph
Posts 6
markph replied on Thu, Aug 9 2012 1:55 PM
Thank you Soren i tried it and im getting the same problem just a humming noise there must be a problem with the inputs.
Kind Regards
Mark.
Søren Hammer
Denmark
Posts 953
markph:
Kind Regards
Mark.
There are both inputs and outputs in RCA plugs (four in total.) Are you sure that you have selected the correct plugs? Is the cable alright?
markph
Posts 6
markph replied on Sat, Aug 11 2012 11:13 AM
looking on the back i used the right two vertical, thank you for your help.
Regards Mark.
Page 1 of 1 (12 items) | RSS
