Beomaster 6000 quad - how to get the brushed steel panel flush again?
This post has 10 Replies | 0 Followers
MrRoast
Posts 340
MrRoast Posted: Tue, Nov 22 2016 8:05 PM
I've been lucky enough to acquire a long-wanted Beomaster 6000 quad in respectable cosmetic condition - however, the brushed panel has lifted away from the aluminium in the areas where it isn't a switch.
Is this a common problem? Can anyone offer any advice on how to get it flush again?
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Wed, Nov 23 2016 6:18 AM
Glue it back down.
MrRoast
Posts 340
MrRoast replied on Wed, Nov 23 2016 7:16 AM
Thank you Martin - a very practical solution! Big Smile
Peter
Earsdon
Posts 11,991
Peter replied on Wed, Nov 23 2016 6:48 PM
What is usually more of an issue is the keys which curve upwards - you also lose the brushed appearance and they go shiny. I suppose glue and a spray of paint is the answer here but tricky to get just right
Peter
Ben_S
UK
Posts 631
Ben_S replied on Thu, Nov 24 2016 7:58 AM
I had to glue mine down too, but it is a common problem and like Peter says really tricky to get right (and not spill any glue on the keys!)
Ben
MrRoast
Posts 340
MrRoast replied on Sat, Dec 10 2016 2:12 PM
Thanks Peter / BenS for your advice.
It definitely feels like there is excess glue underneath the lifted sections as it won't easily press down. Given that 3 of the feet and the stand are missing from the bottom (!?) perhaps the previous owner has attempted to remedy it (not-very-well) at some point?
That's the beauty of badly photographed eBay listings! Big Smile
Peter
Earsdon
Posts 11,991
Peter replied on Sat, Dec 10 2016 4:13 PM
My old dealer had a service department and the excellent technician there told me that the bending up of keys was common and almost impossible to fix easily. One almost needs to remove the whole panel and rebend them down, but that is tricky and is difficult to do without stretching the metal. I have replaced trim with new brushed steel before but not tried a keyboard. The 6000 I had was actually pretty good in that respect - though when last seen, the electronics were looking likely to give the new owner some headaches! Embarrassed
Peter
MrRoast
Posts 340
MrRoast replied on Sat, Dec 10 2016 4:40 PM
Fortunately it's only the non-key parts of the brushed steel that have lifted but as you mention it's the innards that will hold the fun!
I'm more mechanically biased than electronically but the 6000 was an itch that I needed to scratch. Laughing
Peter
Earsdon
Posts 11,991
Peter replied on Sat, Dec 10 2016 4:46 PM
I think all vintage B&O fans do this! It is a spectacular beast and for its time was clearly styled in an incredible fashion - and was remote control. If they has used the amplifiers from the 2000 rather than the upgraded 901, it would have been a stunning machine. It was probably have been easier to package as well as one would not have needed the huge capacitors for the indirect speaker coupling.
Peter
MrRoast
Posts 340
MrRoast replied on Sat, Dec 10 2016 5:46 PM
It was certainly the styling that got me - the concept Beocord 6000 reel-to-reel is sublime! As sound quality I can forgive a pretty face Big Smile - interestingly I once acquired a 2000 from a house clearance and I was taken aback by how good it sounded.
Peter
Earsdon
Posts 11,991
Peter replied on Sat, Dec 10 2016 6:52 PM
Completely agree - wonderful design - the reel to reel is just a mock up unfortunately. The 6000 is not bad - just not as good as some of the other receivers around at the same time. The 3400 probably is actually the better amplifier though not as powerful. It also has the most ridiculous tuning scale!
Peter
Page 1 of 1 (11 items) | RSS
