I was wondering whether I can connect BL speakers to a non-B&O television using an ML/NL converter. Idea is to use the ML/NL line-in and then the PL to connect with the BLs. I am sure there will be audio, but would seek guidance whether video and audio will be in sync with such a setup. Thanks for your help!
This will be possible, but you may get lip-sync issues on either the NL or ML side of your network, depending on which other B&O products you have got connected.
Is there any particular reason why you wish to use the NL/ML converter please? Are the Beolab speaker linked to other NL or ML products in the same room or elsewhere in the house?
If you can please tell us more details of your system then we should be able to give you clearer advice!
Kind regards, Steve.
Steve.
www.soundsheavenly.com
Thanks for your reply. You could use an Essence or Moment for this (these don't have a lip-sync issue if the Network Delay setting is reduced to 50mS or less). The NL/ML Converter should work in a similar way as a connection point for speakers (although it isn't a music source like the Essence or Moment), although I haven't tried using the NL/ML converter in this way myself.
In order to have 'B&O multiroom' you need at least two NL products in your setup.
The NL/ML Converter is not a NL device - it is just a bridge between ML and NL...
....with the addition of being able to connect an analog sound source and BeoLab speakers for local playback.
There is a delay between the Line-In and PL speakers on the ml/nl. There seems to be an assumption that the line-in audio will always be distributed to NL, and therefore is always digitized. To play on the local PL, the digital is taken back to analog. Therefore, you have the delay of AtoDtoA in the audio stream.
I had my turntable hooked up to my nl/ml for a while, and it was odd. Drop the needle, hear the unamplified sound from the tonearm, then it comes out of the speakers. It wasn't horrible, but it was odd. I decided to keep my BL Active for local speaker play.
The Essence works similarly by default (delay), but gives you the opportunity to turn off the "delay". Turning off the delay also prohibits the linein audio from being distributed on the NL. For whatever reason, the ml/nl doesn't give you this option (that I can find).
I'm not sure what you think the ml/nl would give you over the Essence. They cost about the same (if you buy the Essence without the wheelie). You already have a ml/nl so your Essence can access whatever ML sources are available through it. The ml/nl also needs a hardwire to ethernet for NL whereas the Essence can run wirelessly. Maybe I'm missing something...
Stan
