Eclipse 65V1-32Beosound M5Essence MK2BLI
hi,
if your 7.55 is an mk2, I am not sure it would be an upgrade at any level. you would for sure loose the gain of the acoustic lens for center speaker. I use a bl10 better than a 7.4 but I am sure that you already feel the advantage with a bl7.4.
4 beolab 5, beolab 9, beolab 10, beolab 5000, beolab 8000 mk2, beolab 6002, beolab 3500, beovision 7 55 mk2, 2 beovision 11 46 mk4, beotime, beosound ouverture, beosound essence, beoplay A8, beomaster 900 RG de luxe and the collection continues...
mawheele:Much better impact from your BS20s. Avant has much better sound management. The difference is staggering. They will come alive.
If the sound management is as messy than the picture management, it should take age before having a good result.
I don't know for the avant but for the bv 11 the original settings are pure shame compared to the settings of a bv 7 55.
Razlaw:Interesting! And exactly what I was wondering. Same with a BV14?
