Beomaster4400 power transistors
ALF
AUS
Posts 1,015
Silver Member
ALF Posted: Sat, Nov 26 2016 9:16 AM
Greetings all,
I was wondering if those darlingtons Tip141-Tip146 could be replaced by Tip142-Tip147
without any modifications in the power-amp section ??
Thank you kindly for your comments
ALF
beosound
Posts 91
beosound replied on Sat, Nov 26 2016 12:46 PM
Yes! No problem, those transistors can handle a higher voltage, no other differences.
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Sat, Nov 26 2016 5:02 PM
But watch out for counterfeit parts.
They are everywhere.
ALF
AUS
Posts 1,015
Silver Member
ALF replied on Sun, Nov 27 2016 12:59 AM
Thanks for pointing that out Martin,
But:  how do you know which is the real thing and which isn't ??
I was going to buy from 'little diode' in the UK or 'Reichelt Elektronik' from DE.
If I can't trust these guys then I am really  in trouble or am I not ???
ALF
Dillen
Posts 13,191
Dillen replied on Sun, Nov 27 2016 5:13 PM
I would rather not recommend any particular supplier.
I have received counterfeit components from almost all suppliers I have ever used (I believe most suppliers are indeed selling in
good faith and so far I have always got my money back from all known and well-established suppliers when I returned the parts).
And even if I pointed you to one from which I have never received anything but original parts, it wouldn't be any guarantee.
It's getting more and more difficult to spot counterfeit components, but look and compare the lettering, the logos, the
date codes etc. and the general quality and finish of the component.
Don't buy from sellers in China. That's the sure way to get fakes.
Once fitted you are no longer in doubt...
Page 1 of 1 (5 items) | RSS
